br33ch
Jun 29, 2004, 2:20 PM
(3003 views)
Sony KV-C29 11D info required..
i scored this tv in a cleanup nearby, but have no remote. ive worked out most of the front panel controls but need more info such as: - replacement sony remote model (do universals fully work & where in .au can i find them?) - the 2 RCAs at the back do what? is one of them audio in & one RGB vid in (or svid-rgb hopefully) - what are the 2 speaker wire connections for? - one scart seems to work ok with dvd player but i cant get rid of the scart logo on screen - other scart does nothing (scart in?) we dont have scart in .au so i know nothing about it (but i had a cable) ... can these be modified (by hack) to take Svideo-RGB[pal-b]? - where is the AV channel?? is remote required for it? - i read channel 0 is best for VCR in.. true? or does an AV channel work? - is it possible to use svideo, converted to RGB-RCA, converted via sega tv modulator to arial input? i tried this & saw a slight image whilst scanning the channels.. maybe without the modulator?? (i have to try the amiga/genesis(megadrive)/master system also.. - the set shuts down occasionally - i read it may be a power supply problem. anyone actually fixed this problem? info please. - specs/circuit diagrams/photo of remote/manuals/AnyThing! appreciated cheers
