minehunter
Dec 9, 2004, 1:43 AM
(1873 views)
Re: [bwbentz] Sony WEGA KV-32FV27 pin cushion problem
There is pincushion control that can be accessed through the remote. to gain access to the eeprom settings usethe following: push these buttons in this order, Display,5, volume up, power this will put the eeprom info on the screen. To change what you accessing use the 1 and 4 keys. The abbreviation of the item will appear at teh top of the screen. To change values use 3 and 6 keys. to write to the eeprom use MUTING then ENTER. Be very careful doing this and if you don't feel confident about doing then don't. If you do, it's best to write down teh values tat are currently on display before changeing them that way you can go back if you need to. This code works for just about all sonys made since 1994.
