Jun 13, 2010, 10:36 PM
Post #28 of 28
(1267 views)
Re: [gilbio] Sony kv-36hs510 need help
gilbio;..... In regards to these;...
Thanks ron for getting me in the right place with my post.sounds like a problem with 5volts.. & How did you come to the conclusion that you have a 5 volt problem ????... &the 5volts come from service manual that you give me link too. WHERE exactly & on what page do you mean ???? & then where would be a good place to check for the 5+volts if that is what the three blinks say? The 3 blinks do NOT refer to the 5 vdc in any way.... The 3 blink code is;=>....
Blinking 3 times means that (According to page 8 in the manual) you have Low B+ Overvoltage...(Reads like an oxymoron !!!)... That IC6505 is faulty...(D board) I don't know why you are hung up on that 5 volt thing.... You can check IC6505 , but , based on that arcing situation , I doubt that it's at fault....... I seriously doubt that replacing both ICs again would work......... But , then again , they said "No new taxes"...So , who knows........ Your call..... GOOD LUCK......... Let us know what you find.....THANKS........ Later...Ron.M......... Veteran & Retired TV technician
