Jun 25, 2016, 6:08 PM
Post #6 of 7
(6530 views)
Re: [dropgems] Sunbrite outdoor tv fix (am I screwed?)
Good luck finding/affording/having it arrive undamaged Set had a 2-year warranty (with copy of original receipt and a RMA number) - you probably do NOT have receipt. https://www.sunbritetv.com/...rms/limited-warranty IF you were able to get it to them, they would declare TV to be beyond economical repair (BER). This leaves the after market. You can try to find another whole set with a non-LCD panel problem and hope that panels are same. (Yes, same model TVs sometimes change part(s) complement in middle of production.) You can get the panel number off the sticker affixed to the back of panel and try searching for that. This DOES require some disassembly. First you have to find one or the other. IF you DO find one or the other, price has to be acceptable (to you). And finally, you had better hope the seller is in your local area so you can examine item and arrange for transport so that either arrives to your home in same condition as when examined. ------------------------- Location: Far, Far Away
