Megatron
Jun 22, 2018, 1:49 PM
Post #59 of 60
(811 views)
Re: [Megatron] TELEFUNKEN PAL COLOR 2560 white horizontal lines on bright screen
On round cathode connector I have this voltages: R 195,2V G 192,4V B 188,4V When I disconnect RGB cable from connector ST3031 on the same round cathode connector I have this voltages: R 43,7V G 45,6V B 45,3V On RGB cable on connector ST3031 where datasheet say it must be voltages within 135V-170V, I have measured: R 194,3V G 191,7V B 188,5V When I disconnect RGB cable from connector ST3031, I have this voltages on connector ST3031: R195,1V G192,1V B188,5V Turning G2 trimmer potentiometer from min to max I get nothing on picture except luminate and deluminate upper edge of screen 0,5-1cm as on picture: https://ibb.co/nDFSpo Cathode guns are luminating: https://ibb.co/eLzj28 The voltages on videomatrix chip IC401 TDA3562A output RGB pins 13,15,17 should be 2,2V and I have measured 1,0V. When I remove the chip IC401 TDA3562A from the board on the RGB pins output 13,15,17 I have measured 3,1V. With removed chip IC401 TDA3562A on RGB connector cable ST3031 I finaly have normal voltages within 135-170V ,but black screen: R 141,8V G 141,6V B 141,8V
