mlogan32
Sep 9, 2004, 11:09 PM
Post #4 of 12
(7434 views)
Re: [ray] TOSHIBA CF3062A -vertical stretch problem
Hey Everyone- I have a Toshiba CX3285A with TAC 9043 chassis manufactured in 1991. I had a vertical deflection problem (cone heading and/or stretching of vertical). I ended up replacing and/or upgrading the following components: ***Please note… I am giving simplified instructions for the beginner hobbyist.*** *** C stands for Capacitor, such as Capacitor C345*** *** uF stands for micro farads, commonly referred to a MFD; such as 100mfd *** C345 was 100uf 35V upgraded to 100uF 50V C305 was 1uF 50V upgraded to 1uF 250V C342 was 1uF 50V upgraded to 1uF 250V C308 was 220uF 35V upgraded to 220uF 50V C330 is 10uF 50V replaced with new 10uF 50V C342 was the toasted component; but while you have the main board removed, for an extra $3.00 go ahead and replace all of these components. If you cannot find 1uF (250V) radial caps; use the next lowest voltage. Anything over a 1uF 63V will work, but the higher voltage rating the better, since these fry quite often at 50V. Also, I had spent another hour or so troubleshooting this set after all of the mods were made because I still had deflection. I was looking for another cap which may have been bad, but everything was fine. It turned out to be improper labling on the packages. My local supplier sells radial capacitors by NTE. These parts were marked on the package as 1uF 250V when inside they were actually 2.2uF 250V. I went to the supplier to get replacements and the whole lot was the same, so double check. It was partly my fault for not looking on the cap when I installed them, instead relying on the manufacturer to supply the right product. So words of wisdom are to always double check on the component level and never trust the packaging. As for removing the anode (big suction cup on tube), you don’t need to. Just remove the three screws holding the two circuit board carriers together and then slide the main board out after disconnecting the cabling and the two front screws holding them to the base.
