ace960
Aug 23, 2005, 8:16 AM
(961 views)
TV Sony KV-29LS60K - analog stereo output
Hello, I connected the analog stereo output (2x cinch) from TV (Sony KV-29LS60K, 29", 100 Hz) to A/V receiver (Denon AVR-1705). The TV has an option to turn off the internal speakers which will also activate the analog stereo output. I would like to have this configuration so I can then use Dolby Pro Logic II on the A/V receiver to produce some kind of surround sound for the TV broadcast. The problem is that when I turn the TV off and back on (not power cycle, just going to standby state by using the remote control) then the internal speakers are turned on and the analog stereo output is turned off. It is very annoying to set it every time in the menu. The signal from TV is also much quieter than the DVD or Playstation2 ones. I do not know why. Any idea how to keep the internal speakers off and the analog stereo output on? == edit: to increase to volume of the external signal it is required to increase the volume on the remote, that's easy, I thought that the signal is provided as is (not amplified)
(This post was edited by ace960 on Aug 24, 2005, 5:38 AM)
