reconmarine
Jun 2, 2005, 10:10 AM
Post #2 of 4
(1115 views)
Re: [Jfo] TV hit by lightning but it still clicks?
Fuse is inline before the power supply, the fuse is designed to blow and cut power to everything, so a failed component does not damage other components or overheat and cause a fire. If you are still hearing a relay type click the board is getting power, and the fuse is good. If the surge came through the tuner (your cable or antenna) your problems are beyond the power supply.
