TV standby -> power problem and horizontal distortion on image
t0nito
Aug 24, 2004, 8:16 PM
Post #1 of 6 (5005 views)
TV standby -> power problem and horizontal distortion on image Can't Post
Hi, I have a jocel 14" model JT-37N6 tv, I've looked for info on it on the internet and I couldn't find it anywhere. Probably a clone model of some other brand, I believe it's hitachi because I have another jocel model that is a clone of a hitachi. I've noticed 2 problems on the set first, when I press power on the remote the tv clicks and I can hear the HV normal high pitch barely noticeable whine, but nothing happens, no image or sound, I must press power to turn it off and then press it again to turn it back on. The other problems are picture distortion on bright images such as subtitles, the tv's osd etc. It also happens on the AV inputs so it's not a tuner/reception related problem. It also appears on dvd and even on my old nintendo. The tv came with this fault since new, But it didn't go to the warranty. Has anyone had a similar problem? Is it fixable? What may be causing these strange distortions? I have posted some photos to show exactly what I mean:
http://t0nito.no.sapo.pt/tv/photo1.jpg
http://t0nito.no.sapo.pt/tv/photo2.jpg
http://t0nito.no.sapo.pt/tv/photo3.JPG
http://t0nito.no.sapo.pt/tv/photo4.JPG
On photo 4 the osd number should read 13, as you can see it's practically unreadable
please type URL on photo3 and 4 with CAPITAL extension (JPG) not (jpg)
Thank you Sly
(This post was edited by t0nito on Aug 25, 2004, 4:26 PM)
t0nito
Aug 26, 2004, 8:31 AM
Post #2 of 6 (4972 views)
Re: [t0nito] TV standby -> power problem and horizontal distortion on image [In reply to] Can't Post
Hi I discovered that these tv's are made in china and are exported worldwide with different brands. I've also found out that some tv have a sanyo chip and others have a toshiba chip. Could the distortion be fixed through a service menu? I've tried to access the menu with sanyo and toshiba methods but with no luck. I'm also interested in accessing the service menu because I think the tv is over-overscanned (a bit wider and a bit taller, it's cuts a bit of the channels' logos)
t0nito
Sep 29, 2004, 5:43 PM
Post #3 of 6 (4853 views)
thank you for helping
a.coutinho
May 9, 2005, 6:05 PM
Post #4 of 6 (4569 views)
Hello t0nito,
Presumo que sejas portugues, por isso vos escrever em portugues.
Tenho o mesmo modelo de televisor que o teu, e está bloqueado !!!!!
Quando se liga aparece a letras vermelhas sobre um fundo azul a dizer JOCEL.
Passado uns segundos, sobre o mesmo fundo azul, aparece no canto superior direito os seguintes dizeres:
8
ABTO
5.5M
Passados mais uns segundos, no mesmo fundo azul, e no canto inferior esquerdo um icon de um aloquete a vermelho.
No site da jocel, não consta este modelo.
Gosta de saber, se tens o manual de instruções deste TV e se esta situação esta contemplada.
Já tentei melhares de combinações de teclas, quer no comando quer no proprio aparelho.
Qualquer ajuda será bemvinda.
O meu mail é ant.coutinho@clix.pt
Obrigado
A.Coutinho
leozinho
Oct 3, 2005, 8:23 PM
Post #5 of 6 (4173 views)
Re: [a.coutinho] TV standby -> power problem and horizontal distortion on image [In reply to] Can't Post
Boas para entrar no mode service e muito simples, tecla alt do comando e volume menos no tv ate que apareca factory no tv (tecla alt é tecla ao lado direito da tecla P.P) qualquer duvida envia-me um email.
t0nito
Oct 6, 2005, 3:08 PM
Post #6 of 6 (4151 views)
Re: [leozinho] TV standby -> power problem and horizontal distortion on image [In reply to] Can't Post
Muito obrigado pela resposta, eu consegui entrar no mode de serviço e consegui afinal V.size para o tamanho correcto, porém não consegui encontrar o H. size para reduzir tb para o tamanho normal percurri os menus com a tecla zoom e não encontrei... Não haverá um modo para fazer isso? Aproveitei para activar tb a opção 6.0 MHz e as outras linguas do OSD.
