techman995
Mar 26, 2015, 12:17 AM
Post #11 of 12
(2260 views)
Re: [jts1957] Testing Power Supply on Vizio ST472XVT
Checked destinations of all standby voltages. They all went to the same connector on the main board. Measured voltage on solder posts of connector on bottom of board. All same readings of +5.15v, as on the PS board. As I mentioned in the first message, there are no functions that work, no sound, no buttons, no picture, can't turn it on. One concern I have about replacing the main board is that I heard from another source the the LCD panel may have failed and this will prevent anything from turning on, even with a good main board. First of all, does this statement make any sense or is it just someone distributing misinformation on the internet? If this is a true statement, do you know of any way to verify if the panel is bad before I go to the trouble/expense of replacing the main board? Thanks much for all your help.
