Repair man
Jul 29, 2008, 4:55 PM
Post #24 of 28
(146 views)
Re: [jfleming01] Toshiba 36" cinema series
Hello, I'm back, when I last wrote I mentioned the caps would have a black stripe, well your's have gray stripes, this is normal (it all depends on the manufacturer) When replacing then make sure the negative gray stripe goes in the same direction. My first guess of which cap to change would be the small one closest to the IC. In the image all I can see of it is that it is a 35volt cap and what looks to be 100uf (because all I can see in the image is 100), but check it close in case it's 1000uf. If it is 1000uf and you put 100uf in you'll damage the IC again. If that cap doesn't fix it try any others in that general area and again see if they are soldered to a trace line that leads to the IC. If you don't have a local store to buy these caps from you can just take them out of any old TV or electronic device that has the same value. The physical size is not important because different manufacturers will make caps different sizes (height / diameter etc.) but it is important that the value of the cap correct. It has to be the correct 'uf' value and the voltage has to be the same or higher. For example the cap I'm suggesting to change first is a 35volt cap, do not use less than 35 volt cap but you can use a 50 volt or 100 volt etc. what ever is available to you. This line you are having could also be a result of the one leg you had trouble with (the one you said you couldn't get solder to stick to it) If this is the case, you could solder a small jumper wire from that leg to the next spot down the trace line that it is supposed to be soldered to. In other words, if you can follow the copper trace line that this leg is supposed to be soldered to, it will come to another point at which another component will be soldered (such as a cap or resistor etc) you can solder a thin gauge wire from the leg of the IC to the next point of that trace line. -- Dan ________________________ Learn LCD / Plasma TV Repair
(This post was edited by Repair man on Jul 29, 2008, 5:06 PM)
