cslimdr
Feb 26, 2003, 1:15 AM
(7181 views)
Toshiba 38D9UXE 38" projection TV
I bought a Toshiba 38 inches projection TV ( Model No. 38D9UXE) In July 2001 with a warranty period of one year. It broke down in November 2002. What happened was that when the TV was switched on, the sound came on for about one to two seconds before the whole TV went dead. A green light located at the centre of the front panel continued to blink. I called up the local Toshiba service centre, and they immediately knew what the problem was (probably a very common problem). A technician repaired the fault by changing a 'fused bulb'. Cost of the repair for parts and labour came close to $400. Warranty period for this repair was stipulated as one month for parts and labour. Unfortunately, the same problem recurred again last night! What I like to know is whether anybody out there has encountered the same problem with this TV and if so please advise. Your help is most appreciated. Thank you. CS
