Gus67
Jan 13, 2010, 4:05 AM
Post #19 of 253
(18259 views)
Re: [jts1957] Toshiba 42H81: Convergence repair?
Man it sucks throwing parts at something and still not fixing it. One suggestion before freaking out...(take a step back...think for a moment) and look for simple mistakes you may have made. Check all your solder joints and the connections to the heat sink in respect to the component you swaped out Is the heat sink isolated from the component, or making a path to ground? is it suppose to be floating,or grounded? is there a mica washer and heat transfer grease on the component?is the screw you used to attach the heat sink isloated from the component? Also, Spend a few min.tracing all the tracks on the board that you soldered.Sometimes when you remove a component that has a number of legs, you will tear a track on the board due to not having all of the legs free from the board.It's easy to remove a component with only 2 or 3 legs.When you have something that has numerous legs you may tend to pull the component out,and in doing so,damage the tracks and the thru holes.So when you replace the component you may not have a good solid connection. one more, In one of these posts,I believe I read you commented on a bulged resistor...are you sure it's a resistor?..maybe it's a blown Cap? and if so,what caused the damage...maybe something other than what you are looking at. .
