Larry E
Aug 3, 2006, 6:41 PM
Post #5 of 5
(4334 views)
Re: [DOLLAR] Toshiba 62HM84 DLP projection TV problem
This is exactly why I have posted in the past that, "if your not a tv tech why do you think you can fix a tv"? The advice you got from the other post is correct, intermittent lamps can cause start-up problems, so can a bad ballast, defective power supply, clogged filters, fan doesn`t run etc, etc. Some sets require you to re-set the lamp timer as well, could be a dozen different thing, that`s why we go to the training seminars every year and WE still have sets that give us trouble, CALL a TECH, Larry E
