vcrguy
Nov 12, 2004, 9:21 PM
(1857 views)
Re: [vcrguy] Toshiba CN36Z71 shaky pix
As I had mentioned, I used a 25" RCA CTC203 to test the chassis (instead of carting around a 36" monster from the customer). Apparently, this was the problem. I have used this jig to test 36" RCA's without any problems. However, it does not work on the Toshiba chassis. Once I reconnected the chassis to the customer's 36" tube/yoke, the tv worked like a charm. I can now blame the vertical shakiness on the mis-matched yoke. Also, I discovered that the 12 volt regulation section had problems . The feed resistor developed ring cracks. The support caps around the actual regulator were leaking. I wish Toshiba would have placed this circuit where I would normally find it. I would have discovered the problem earlier. So this is how the whole thing started. 12 volt regulator develops problems and creates intermittent feed to jungle ic. Jungle ic, in turn, develops intermittent horizontal drive to driver and in turn to horizontal output. When output is underdriven, it shorts. Thank God flyback is ok. Same situation on Sonys with ring cracks on driver transformers and RCA CTC203 with ring cracks on L4401 coil which is base feed to horizontal output. Thanks everyone for your help. Ron.
