Troz
Feb 2, 2005, 5:42 AM
Post #1 of 4
(2117 views)
Toshiba TP50F51 looks like a fisheye lens
Hello, My father has been having trouble with his Toshiba TP50F51 projection set for a few months now. The majority of the time the screen looks as if everything was filmed with a fisheye lens. The convergence is off on all four corners of the set. Sometimes, after the set warms up, the fisheye look goes away and everything looks normal. He had a tech look at it and they had no idea, but said a minimum of $350 with no guaranteed date back. After searching around here a while, I found what sound like similar problems where one of the guns goes out of convergence in a rounded pattern. In those cases, replacement of stk392-110 fixed the problems. Does anyone think replacing that component may help this problem? Also, occasionally the screen will go completely blank for a short period of time. Thanks for any advice. -Karl
(This post was edited by Troz on Feb 2, 2005, 5:44 AM)
