70JUDGE
Aug 7, 2010, 8:37 AM
Post #8 of 17
(6620 views)
Re: [jts1957] Trutech PLV16260 LCD TV Turns On For A Few Seconds Then Turns Off
I took the inverter out,and looked over the coils a little closer.There were two that looked like the tape around them was white.I thought they were bad,but they tested fine. The inverter doesn't have two 16V capacitors,it has four 35V ones.The inverter is a Logah brand. As far as the wires,there were four of them,but someone cut the two ground wires off.The other two are the backlight on/off,and the brightness. After I put the inverter back in,I took the heatsink plates off,and looked at the power supply a little closer,but didn't find anything different,so I put it back together. When I went to test the TV out,it stayed on longer then it ever has.A little over a couple of minutes before it turns off by itself with no sound,or picture,and the standby light off.I thought maybe it turned on so long because I might have put presure on the coil terminals testing them,and it turned off because the cable wasn't hooked up?After that,I turned it back on again,and it stayed on until I turned it off a minute,or two later.Next,after I put the back on,and hooked it to the cable,it stayed for what I'm guessing a half hour,then it turned off while I had it on mute.Thinking the mute had something to do with it,I left the sound on with the one speaker I had hooked up,but it still turned off whenever it felt like it.Usually around a minute,or two.For awhile I could turn it off,and back on when it tuened off by itself,but it got to the point where I would have to unplug it,and plug it back in to get the standby light to light red so I could turn it on again. As far as the standby light goes,that is the way it is setup.When you plug the cord in,you have a red standby light.When you turn the TV on,the standby light turns off,and the TV turns on. I would say that it might be overheating?Either that,or the coils need to be resoldered again,because they are heating up,and separating.Does the metal cage around the inverter act as a heatsink?All this time I have had it off.I also took the paste off the heatsink plates when I first started having trouble,so they are metal to metal.Before that,I had Arctic Silver on them when it started turing off by itself.Thank You very much! Tyler
