LouF
Apr 6, 2017, 5:58 PM
Post #1 of 16
(1621 views)
Tube TV cuts out when cold
I have a older tube-type TV that I infrequently use and is on the fritz. I have recently de-shunned it as it has actually been a very good TV (1st anything in 15 years except for cleaning the remote control button contacts (and most everybody calls things like this a "little POS (that's not Point-Of-Sale)" TV )) TV make and model: Emerson-TC1966D (a 19 inch tube TV). Problem: turns off (sound and picture) when initially turned on (cold); will eventually stay on. A 1/2 hour of warm-up time allows it to continually stay on. No capacitors are bulged; no leaks on the board. With this minimal diagnostic information, I am hoping that someone can suggest the probable cause. I am hoping it has to do with the power supply and is a capacitor(s). I have tried looking and reading, but it quickly turns into (for me) knowing about SMPS design, off-board component testing etc... all that I just can't do (plus, I have a brake line to urgently fix too) - but I don't want to just toss this away. There is a bigger cap. (560 uF, 200V) near the line-voltage in that I want to first try. I would have, but as of last week the Radio Shacks have closed so I can't even easily try a remove-and-replace method; MicroCenter has even less basic-component stock. Then there are many, many other caps. that I don't believe are bad. All solder joints appear good (two a bit dull, but are not suspected); several browned areas, but nothing severe; I feel its a simple component degradation over time. Credibility check: I'm a decent repair person, but the complexity that electronics has gone (although this is old , but still very complex) is beyond what my novice, fluent, electronics knowledge can keep on tap. I have successfully repaired a sub-woofer system, have installed car stereos, build my own computers, rebuilt solar stake lights ( lol) and other various other things - so the experience here would be appreciated to get to me pointed in the right direction. The long post is, since I just signed up here, to introduce myself and not just blasting in as a complete know-nothing. Thanks
