Aug 21, 2004, 10:57 PM
Post #6 of 6
(2125 views)
Re: [troy willis] Vertical Collapse Toshiba CX32C81
The schematic that you need is spread out over several page so it is difficult to scan to send it to you. Check to see if you have 28 volts on pin 6 of the IC. If not, check F301. That is probably where your problem lies. Also, check D302, when it smoked R327, it may have also smoked the diode. You can also go to the SAMS website and download a schematic for $20. They do not have one for your exact model number but SAMS #4151 looks like a close match.
