Jugador
Jun 1, 2010, 2:04 AM
Post #8 of 8
(5813 views)
Re: [Repair man] Vizio 46" lcd (pic included)
Hey guys...felt like I needed to add an update to this problem in case someone else was trying it and getting different results. It worked a couple of times and then sometimes it wouldn't work. So, what I discovered was the panel "bad spot" can be at random places. So, what I do now is grab a soft cloth (in my case a sock), and rub all over the monitor like your cleaning a window, and it will fix again. Sometimes the "spot" will be on the right side, sometimes on the lower left side! Anyways, if you tried tapping the edges and got nothing, try wiping the whole monitor like window with light pressure. That's working here...cheers.
