HelpMeThanks
Aug 9, 2017, 12:15 AM
Post #1 of 9
(4114 views)
Vizio E320-A1 no picture or backlight.
Hello, I have a Vizio E320-A1 TV that does not have a picture or backlight. When I turn the TV on its power light stays on in a white color. Once it is on I cannot turn the TV back off (turn the light off). Holding/pressing the power button does nothing to turn it off. If I plug the TV in the light comes on and stays on. If I unplug it, hold the power button for 15-20 seconds, then once I plug it back in the light will not come on until I press the power button. Holding a flash light to the screen when the power light is on does not show any visible picture and the backlight does not come on as well. Also, if I do the above where I unplug the TV, hold the power button and then plug it back in, then the TV makes a slight high-pitched noise just like any TV that is on. There is no picture here, and once I press the power button the noise goes away. Pictures. Power board: http://imgur.com/a/k961c Main board: http://imgur.com/a/zynDy Tv info: http://imgur.com/a/jzxob Pins from power board to main board: http://imgur.com/a/ZYEBk Alright, here are the voltages from the last picture's pins: OFF/Unplugged after holding the power button down for 15-20 seconds:
ON/OFF: 0.0v DIM: 0.0v 12V: 0.0v 12V: 0.0v GND GND GND 12V_Audio: 0.0v 12V_Audio: 0.0v PS_ON: 0.0v 5.2V: 0.0v 5.2V: 0.0v NC>: 0.0v OFF/Unplugged after holding the power button down for 15-20 seconds, plugging back in, pressing power button, and unplugging again:
ON/OFF: 0.0v DIM: 0.0v 12V: 0.01v 12V: 0.01v GND GND GND 12V_Audio: 0.01v 12V_Audio: 0.01v PS_ON: 0.01v 5.2V: 0.01v 5.2V: 0.01v NC>: 0.0v ON?/Plugged in, power light off:
ON/OFF: 0.03v DIM: 0.04v 12V: 11.89v 12V: 11.89v GND GND GND 12V_Audio: 11.89v 12V_Audio: 11.89v PS_ON: 0.09v 5.2V: 5.11v 5.2V: 5.11v NC>: 0.0v ON/Plugged in, power light on:
ON/OFF: 0.06v DIM: 0.09v 12V: 11.68v 12V: 11.68v GND GND GND 12V_Audio: 11.68v 12V_Audio: 11.68v PS_ON: 5.08v 5.2V: 5.10v 5.2V: 5.10v NC>: 0.0v Any ideas on what could be wrong with this TV? Thanks for any help!
(This post was edited by HelpMeThanks on Aug 9, 2017, 1:39 AM)
