Vizio TV E322VL, won't turn on. Vizio light just blinks
chrisfromwa
Jan 17, 2017, 11:08 PM
Post #1 of 10 (3916 views)
Vizio TV E322VL, won't turn on. Vizio light just blinks Can't Post
Hello,
My parents had a Vizio TV model number E322VL.
It's had this problem where it won't turn on, all it will do is the Vizio light on the front will just blink on/off.
It's had this issue in the past, and it would just all of a sudden start working again. But this time, we can't seem to get it to work.
I've already tried unplugging the unit, and pressing the power button for 30 seconds, but no luck there.
Does anyone have any ideas or testing that I could do?
I looked up a main board for it, and they seem to cost more than the TV is worth. So hoping it's a component I can replace and it will start back up.
It just seems odd that it's done this in the past, but those times it would eventually start back up.
Jan 18, 2017, 1:39 AM
Post #2 of 10 (3906 views)
Re: [chrisfromwa] Vizio TV E322VL, won't turn on. Vizio light just blinks [In reply to] Can't Post
http://www.shopjimmy.com/...-u18-eeprom-only.htm
chrisfromwa
Jan 19, 2017, 4:50 AM
Post #3 of 10 (3898 views)
Re: [jts1957] Vizio TV E322VL, won't turn on. Vizio light just blinks [In reply to] Can't Post
oh sweet, is it a pretty good chance this is the troubled component? Is there anything I should check before I order it?
Jan 19, 2017, 5:08 AM
Post #4 of 10 (3896 views)
Go to the link ... read all the info there ... and decide if your symptoms match any on list. (I've also seen them cure a couple of things that aren't on their list)
It's one thing you can try.
chrisfromwa
Jan 20, 2017, 1:56 AM
Post #5 of 10 (3887 views)
I read that, and it sounds like this will fix it.
Do you happen to know where this compontent is on the board? There seems to be a lot of EEproms like this, but not sure which one it is.
Jan 20, 2017, 3:52 AM
Post #6 of 10 (3886 views)
Picture and everything! Make sure you have same board number.
http://www.ebay.com/...%26sd%3D221403331821
chrisfromwa
Jan 24, 2017, 11:57 PM
Post #7 of 10 (3843 views)
Looks like I have a different board number.
Mine is: 0171-2272-3353
Looks like the Shop Jimmy one is for a different board too?
Jan 25, 2017, 12:50 AM
Post #8 of 10 (3841 views)
http://www.shopjimmy.com/vizio/e322vl
As you can see there is more than one Main board in use for your model.
chrisfromwa
Jan 25, 2017, 1:02 AM
Post #9 of 10 (3839 views)
I might just be missing it, but not seeing anything that matches my board #
Jan 25, 2017, 1:29 AM
Post #10 of 10 (3836 views)
Since many people can't tell a parts number from a board number and since SJ usually only show board parts numbers in their headers ...
http://imgur.com/a/edgGA
