Feb 13, 2008, 7:30 AM
Post #3 of 5
(114 views)
Re: [Brinky] Voltage at the Antenae
Several things I think here. 1 you are getting to technical and are finding issues not there. The TV has but one antenna, though it may have 2 rods, its singular. 2 you didnt say where you are from, that you talk of DSE I assume that you are down under. The TV has no capacitor between the tuner and the socket, in fact the socket is part of the tuner. 3 the TV is double insulated, it has only 2 pins and no earth pin. This uses an isolated supply. Your issue then is static, when you stick a meter between earth and the antenna you will have floating eddy currents which could give you all sorts of readings, but all are false. Now that you have found a tickle what you are doing is the cat dance. will I touch it , no, yes , oh no and then you lightly touch it and get a zap. Grab it and you wont feel it, do the cat shuffle and it will bite.
