pnb
Jun 23, 2013, 10:05 AM
Post #6 of 9
(2558 views)
Re: [74f100] Wierd plasma screen behaviour as tv warms up. Anyone identify?
Hi, I made the test you suggested. First off I checked and fine tuned all voltages ( VS, VA, -Vy, VSC, VZB) which had minor deviations of a volt or two. I dont have an oscilloscope so cannot check waveform. I completely removed the lower board Y-drive board (physically) including all ribbon and TCP cables and ran the set for a minute. This is the result: multicoloured unmoving blotch. (On top half of screen and obviously exactly half of the screen, whereas the issue I am having is for an area less than half of the screen. I only ran it for a minute. Not sure a 5 minute test would have made a difference as the problem normally only starts after the set has been on for 5 minutes.
Not sure what that means? While I had that lower board out I took some photos. No visible evidence of damage but the main chips are covered by a heatsink.
Underneath the board there is some curious solder run under a few of the pins on 3 of the chips, but no short circuit.
Checked the heat of the Ysus board as the issue seems to be heat related. One of these heatsinks gets astonishingly hot (see photo). But maybe that is normal? Checked the back of the board, no evidence of bad solder joints due to heat, touched up the transistor legs to be sure. Inspected all other components with magnifying glass, no obvious damage.
At the bottom of the rightmost heatsink is a mosfet? which I suspect is the source of most of the heat on that heatsink as the board is much browner around it's legs than the other transistors along the line which are of a different type. The chip is stamped as K8A60DA 1:8
I only have a 30w soldering iron, so I know it would be nigh impossible to get that line of chips on the heatsink out for testing. There is a chance I could get it off the heatsink in-situ and then de solder it, but will only attempt this if this sort of chip has a high probability of causing the effect I described. Apart from that the only observation I can make is a buzzing from the ysus board that corresponds to the lower half flickering but I guess that is only to be expected as signal frequency cuts in and out? Put is all back together and it is back to it's old behaviour - after a couple of minutes the bottom 2/5ths start flickering and it gets darker/worse with occasional brief flickers of clarity.
(This post was edited by pnb on Jun 23, 2013, 12:43 PM)
