534881
Feb 28, 2005, 12:29 AM
Post #4 of 10
(1719 views)
Re: [lamer] Zenith 32" SL3285BG Blows fuse
THE NEXT THING I DO IS DISCONNECT THE BOARD FROM THE SET AND TRY TO FIND THE SHORT WITH A VTVM.GETTING THE SERVICE INFO SEEMS TO ALWAYS BE A HASSLE UNLESS YOU JUST PAY SAMS THE 20 DOLLARS FOR THE SCHEMATIC. THE HIGH FAILURE RATE ITEMS ARE USUALLY THE HORIZ OUTPUT TRANSISTOR, FLYBACK AND THEN CAPS IN THE HORIZ SWEEP CIRCUITS. DEPENDING ON THE CIRCUIT DESIGN, A HORIZ CKT CHIP/IC IS ALWAYS MY NEXT SUSPECT. GOOD LUCK
