snifferdude
May 4, 2005, 1:29 PM
Post #5 of 5
(1503 views)
Re: [Bursma] Zenith 9" TV remote A09P02x - SC3470
That is the problem I've been running into.... The Input button (TV/VCR, etc.) allows you to switch between physical sources. What I need is something to allow me to select the format of the input source. It has a 75 ohm connector on the back, with an telescoping antenna with 75 ohm connector. If you connect the telescoping antenna, it works fine, but available channels are limited. If you connect a cable from COX cable, there are more channels, but they are not all there, and the ones that are are grainy/fuzzy. This appears to be because the signal format is cable, not antenna. This function is normally set via setup menu, which this tv does not have. The original remote had a button that was designate "TV/CATV" which selected the source format, not the actual source. I appreciate your help, and it is looking more and more like I will have to go with an original remote unless someone can come up with an alternate solution..... Thanks
