Aug 23, 2004, 12:11 AM
(2331 views)
Re: [dschnittker] Zenith A32B41W- Red Tint
Are there adjustment potentiometers on the CRT board? if so you need to turn the color off and adjust these pots to a good black and white picture. They will be labeled red, blue and green screen. If you do not find these pots, the set has a service munu function which you will havr to acces to make these adjustments aand I do not recommend that a novice access the service menu.
