Apr 18, 2007, 8:49 AM
Post #2 of 5
(1975 views)
Re: [007dust] Zenith SR2549S flyback problem
Sorry you are not talking common sense, you are talking you dont know. First vertical is top to bottom, I know this sounds condescending, it is not, as I cant see I have to be sure you know the difference and as Im going to talk about horizontal scan issues it becomes somewhat confusing. You have no horizontal scan but you have EHT. Forget about discharging the flyback, there was no voltage there its on the cap on the centre of the tube, dont remove that and all is OK. You have a very simple fault, 99% its a bad connection. Look at the coils on the tube neck, there is a lead from that with 4 wires, go gown to the board and check the socket that plugs in to. Next there are large capacitors, check they are OK. But do not get the part you think, it aint that.
