cdawley1
Jun 14, 2003, 7:37 AM
Post #1 of 3
(1922 views)
Zenith model# PVY4665DT 46" won't power on
I have a 46" big screen TV that my step grandfather gave me. It doesn't power on. I checked all the fuses and none of them are blown. I also checked the fuses with a ohm meter and made sure they were good. I put them back in place and tried to power on but no luck. Should I go ahead and replace fuses, even though they are still good or is there some other components that could have jarred loose during loading and unloading? It was mfg in September 1996. I am just guessing that it probably has about 50-100 hours of use on the projectors and components since my grandfather didn't watch it much. Just for informational purposes, I know the next question that you will ask is "Did I check the power supply?" I checked it and it has 120V coming into it. It has been so long ago that I am not sure how much is coming out. Will re-check and post during my next post. Any suggestions would be helpfull. Thanks.
