Oct 26, 2007, 4:12 AM
Post #4 of 15
(1428 views)
Re: [TVRE] MAGNAVOX RM8341 Can someone just answer this question?????
You are in danger of doing the tv or yourself a mischief. First DO NOT measure on the primary of the transformer unless you have to. Never measure voltage across the transformer primary to secondary. standby transformers are usually mains driven so the only measurement there is pull the TV plug switch on, pull off the degauss plug and measure the primary for ohms, none its open. If you do have a primary fault then you have to follow strict rules and know a bit more than I think you do. Set your meter to DC, find the secondary of the standby transformer, there will be a diode on that, find that diode or bridge diode block, that will feed an electrolytic, measure across that electrolytic for DC volts and you would expect that to be under 20V. if it is zero your supply is faulty and you have to chase that down.
