Sony KDL-46XBR6 partial dark screen
Aliac9000
Jun 11, 2019, 5:16 PM
Post #1 of 5 (1821 views)
Sony KDL-46XBR6 partial dark screen Can't Post
This TV's LCD screen has a dark vertical band in the centre, increasing gradually to normal brightness on either side (please see link to photo below). The band in the centre still shows the video; it's just not backlit.
I'm guessing the backlighting is the problem, and that the backlight components are an integral part of the screen (i.e., not individually replaceable), meaning the TV is toast.
Am I right about this? It's only later Sony TVs that came with LED backlighting that's replaceable independently of the screen, correct?
Thanks in advance for any help I can get!
https://photos.app.goo.gl/kBjCQun4H7PrKzvXA
(This post was edited by Aliac9000 on Jun 12, 2019, 3:41 PM)
Jun 12, 2019, 3:22 PM
Post #2 of 5 (1815 views)
Re: [Aliac9000] Sony KDL-46BR6 partial dark screen [In reply to] Can't Post
For the 'correct' model, tis CCFL back lights. You'll have to partially disassemble the panel to observe lamps. https://www.shopjimmy.com/sony/kdl-46xbr6
could also be inverter board
http://www.lcdparts.net/CCFL13D.aspx
Aliac9000
Jun 12, 2019, 4:07 PM
Post #3 of 5 (1807 views)
Re: [jts1957] Sony KDL-46BR6 partial dark screen [In reply to] Can't Post
Thanks for the leads. And for the heads-up on the 'X'!
yezom999
Jun 26, 2019, 7:21 PM
Post #4 of 5 (1744 views)
Re: [Aliac9000] Sony KDL-46XBR6 partial dark screen [In reply to] Can't Post
hello Aliac9000,
the issue you are facing can be sometimes due to BAD LVDS FFC Cable and it can be easily fixed just by using new cable. here is an image of what you need to check https://ravielectronics.in/...c-e1561576687742.jpg
reply if if problem still there.
Aliac9000
Jun 26, 2019, 8:32 PM
Post #5 of 5 (1736 views)
Re: [yezom999] Sony KDL-46XBR6 partial dark screen [In reply to] Can't Post
Thanks for the suggestion.
Unfortunately the image link you provided yields only a small graphic which doesn't show any electronic component.
Could I impose on you to check that link?
Thanks in advance for your help.
