aluminum welder
Mar 10, 2018, 2:15 PM
(682 views)
diy sunbrite skyview outdoor TV, Just add more leds to regular tv?
I had a worker that used to work for an outdoor tv company. He claims that all they do is add more leds to the inside of led backlite TV's and then make a special housing so the tv is water proof with vent fans and such. I want to make an advertsing kiosk that will be in a very bright area some times, so I need the brightness but not the water proof factor. I know the blacks will turn to a dark gray when one has more backlights and I know adding a small fan would be prudent to prevent heat build up. has anyone done this? would a HDR tv be superior than a standard one to modify? I have taken apart a standard LED backlight tv, but I have never taken apart an HDR one, is there something in HDR TV's panels/lcd that makes them keep blacks better or are better blacks solely due to localized led diming? thanks for insight!
