crawdaddy
Feb 14, 2005, 3:21 PM
(1005 views)
Re: [ohms] high pitch sound comes and goes in 14 inch rca
I've run into this too, especially when the boards are a little tight sliding back into the cabinet. Mel's solution is probably the right one, most of the time,it's either the flyback with a couple of poorly soldered pins(because of those damn "rivlets"), or a coil or small transformer like the horizontal driver transformer that has worked itself loose due to heat cycling. As you know there is mechanical stress as well as electrical stress on these components so weird noises can be hard to trace. Good luck, let us know what happens
