Repair man
Jul 22, 2008, 2:33 PM
Post #13 of 16
(11471 views)
Re: [erickeri] jvc av-36f702! won't turn on. timer light flashes red.
It's hard to explain how to test them but I'll try, it's often easy and cheap to change them. You can but them both for under $5 . The H.O.T. is $2.15 and the vertical IC is $1.19 from HERE when ordering the H.O.T. you must add 2S in front of the part number 2SD2645 To test the HOT check to see if it's shorted across all of its legs, if it is it's bad. The vertical IC has 7 legs and none of them should be shorted to each other. To test for shorts using your meter, set it to the lowest setting on the ohm scale (or ideally if your meter has a diode setting use it). Touch the two leads of your meter together and observe the meter reading, this is a short. Now test between the legs of the IC, if you have this same short or same reading then the IC will be damaged and needs to be replaced. To test the HOT, between the emitter and the collector it will read shorted, this is normal but it should not be shorted across any other legs, if it is in needs to be replaced. When I say it's normal to be shorted across the emitter and collector, this is only for some Transistors, your 2SD2645 is one that will read shorted, this is due to some internal circuitry of that particular transistor. To test these parts, they have to be out of the TV. Dan ------------------------------------------------------------------------------------------ If you (or anyone reading this post) have any further questions or need clarification please feel free to contact me direct; you can find my email address by clicking on my user-name. Learn Plasma TV Repair _________________ Learn LCD TV Repair
(This post was edited by Repair man on Jul 22, 2008, 2:51 PM)
