Apr 12, 2005, 10:09 PM
(1158 views)
Re: [rodm] misubishi model#CS27303 instruction for pip card replacement
Remove the VP plug from the PiP module. Install a .01 mfd cap between pins 9 and 7 and a 4.7 mfd 50 volt cap between pins 5 and 11 with the neg lead to pin 11 in its place om the main board. You might also want to check out www.FreeFlatScreens.com/?r=10948674 for an opportunity to earn a free replacement for this set with a little effort on your part.
