panasonic television child lock
mike03
Apr 21, 2012, 1:03 AM
Post #1 of 27 (28901 views)
panasonic television child lock Can't Post
Hi guys good work on providing information to assist others like myself. My problem is of a Panasonic television set model#TC-20RM10L the issue i have is that here is that the television is child lock and i cannot remove it because the owner does not remember the code. I was told to hold the sleep and volume down and that should reset it but the remote is broken. I tried to program a universal remote to the unit but all the codes for Panasonic just did not work, I tried searching the internet for codes that work for this particular brand but with no success. Another guy suggest removing the e prom chip but i dont know which one it is because i also cannot find the service manual. Any help will be appreciated.
MK
Apr 21, 2012, 1:08 AM
Post #2 of 27 (28892 views)
Re: [mike03] panasonic television child lock [In reply to] Can't Post
http://elektrotanya.com/...egoria=&kat2=all
Apr 21, 2012, 1:36 AM
Post #3 of 27 (28883 views)
mike03;....
Replacing the eeprom opens up a whole host of new problems & ADJUSTMENTS you'll have to deal with unless you are an EXPERIENCED TV tech....
My suggestion would be to get an original remote for the TV & try that method again....
Later...Ron.M...Cool....
mike03
Apr 21, 2012, 1:54 AM
Post #4 of 27 (28878 views)
Re: [jts1957] panasonic television child lock [In reply to] Can't Post
Thanks for the link man but the info i am looking for i just don't see because the manual did not display a e prom chip on the board.
MK
mike03
Apr 21, 2012, 1:57 AM
Post #5 of 27 (28876 views)
Ron i suspected problems. I will not be getting a original remote for it no time soon and the universal codes i just cannot find anywhere
MK
Apr 21, 2012, 2:35 AM
Post #6 of 27 (28865 views)
mike03;....
My GD computer is playing games again with Elektrotanya...
It is stopping downloads at 3.79 MBs...
Reason I'm trying to get the service manual is to get the number of the original remote & see if I can locate a cheap replacement...
Two roadblocks are in my way , #1 , the TV appears to be a TV made for the UK & #2 , you appear to be living in Jamaica which will be hard to find a shipper that will ship to Jamaica....Unsure....
Care to explain ???
That could be because of where the set is made for &/or the model number....
Have a GREAT evening....Sly....
Later...Ron.M....Cool...
(This post was edited by Ron.M on Apr 21, 2012, 7:14 PM)
mike03
Apr 21, 2012, 2:53 AM
Post #7 of 27 (28861 views)
Re: [Ron.M] panasonic television child lock [In reply to] Can't Post
OK man thanks. I just had another look at the tv and it was made in Brasilia and the model# has a P at the end so that should be TC-20RM10LP
MK
Apr 21, 2012, 3:12 AM
Post #8 of 27 (28860 views)
TQB2B0146 OPERATION GUIDE
TNQ2B2502-1 REMOTE CONTROL
Apr 21, 2012, 7:11 PM
Post #9 of 27 (28845 views)
mike03;....
OK , I've had success with the service manual download...
jts1957 IS correct on both numbers...(Would anyone dare to challenge his accuracy ???)...
However , I've been banging my head on my monitor (For about 2 hours..)...trying to find a user's manual....
Since the TV was not made for use in the USA , the manual & remote needs to be gotten from a supplier outside the USA...
The "Child Lock" use & how to bypass it in the event the code is lost or forgotten is in the "Operation Guide"...
Look on the model label for the following;=>..
if you look on the back or bottom of your
panasonic you should find a website then go to it and you should
be able to link to a user guide and you can download it
IF there is one there , PLEASE post it here so I can probably do some magic....Wink...
Unless someone here knows how to bypass the code , you are going to have a 20" doorstop or boat anchor...Unsure...
You WILL also need a working remote....
I did have some success with locating the remote at the website below...
http://www.remote-controls-shop.co.uk/...&model=TC20RM10L
Good Luck....Sly....
Apr 21, 2012, 10:47 PM
Post #10 of 27 (28836 views)
Re: [mike03 & Ron.M] panasonic television child lock [In reply to] Can't Post
HOW TO RESET THE UNIT (SELF CHECK)
To reset the unit, press simultaneously “VOLUME (–)” on the front panel and “TIMER” on the remote control.
Best bet for this is ORIGINAL Remote - 2nd best try a Panasonic Universal Remote with a (dedicated) timer button. (Almost ANY Universal Remote should, once programmed with the CORRECT code, be able to (at least) turn the set ON/OFF even with the set in Child Lock or (if equipped) Front Panel Key Lock engaged.
SELF CHECK is NOT the same as Service Mode.
I don't see any list of what al SELF CHECK actually resets, but SM says:
TO EXIT SERVICE MODE AND RETURN TO NORMAL MODE
To exit SERVICE MODE, turn off or reset (SELF CHECK) the television.
As Ron.M said there may (or may not) be a reference to this (or another method) in the Operating Instructions.
(This post was edited by jts1957 on Apr 21, 2012, 11:09 PM)
mike03
Apr 22, 2012, 12:20 AM
Post #11 of 27 (28826 views)
I know that i will not be getting the original remote but i have been searching for codes for the universal one that i have that always come in handy. Every television set has a unique code to accommodate a universal remote should the original remote fails.
MK
Apr 22, 2012, 2:11 AM
Post #12 of 27 (28821 views)
And every Universal Remote manufacturer can only install the codes that were already around as of the date of manufacture. So IF, for example, you are trying all the codes on the sheet of the universal remote that was purchased in say approximately 2000, it MAY not work on your TV that was purchased in approximately 2005.
Also, there could be a problem with the TV's remote RECEIVER.
mike03
Apr 22, 2012, 4:20 AM
Post #13 of 27 (28817 views)
That is why i tried searching the net and hoping to find the code for this particular model tv set.
MK
Apr 22, 2012, 5:19 AM
Post #14 of 27 (28816 views)
Dare I ask which Universal Remote you have?Wink
mike03
Apr 24, 2012, 12:35 AM
Post #15 of 27 (28806 views)
RCA SYSTEMLINK 4
MK
Apr 24, 2012, 2:38 AM
Post #16 of 27 (28802 views)
I have a Sony universal RM (I believe) 7 which has been replaced by an RM11 and it works fine with all functions on my Panasonic Plasma flat screen. Might be worth a try.
mike03
Apr 24, 2012, 4:41 AM
Post #17 of 27 (28801 views)
Re: [mel] panasonic television child lock [In reply to] Can't Post
Can you share the codes in your manual with me for panasonic tvs?. I could try them and maybe one of them might work.
MK
Apr 24, 2012, 5:57 AM
Post #18 of 27 (28798 views)
RCA SYSTEMLINK 4 is a generic term for a RCA remote that will operate FOUR items.
Find a number like: RCU400, possibly inside the battery compartment.
mike03
Apr 24, 2012, 8:07 AM
Post #19 of 27 (28794 views)
RCU 404
MK
Apr 24, 2012, 8:43 AM
Post #20 of 27 (28791 views)
Panasonic............................................................. 003, 012, 013, 025
http://files.remotecentral.com/...u404-manual.zip.html
2003 Remote 2005 TV - I would think they are close enough. Pana didn't change codes all that much back then.
(This post was edited by jts1957 on Apr 24, 2012, 8:47 AM)
Apr 24, 2012, 6:49 PM
Post #21 of 27 (28777 views)
jts1957;....
""2003 Remote 2005 TV"""
Code sheet link you gave = Updated November 8, 2009...
Would normally do the job....
However;....
RCU 404...
There's NO Timer button on his remote....Unsure....
SOOoooooooooo.......
Good luck with that idea.....Wink....
IF he finds a code that will operate the TV , he WILL STILL have to deal with the "Child Lock" issue...
Have a GREAT day & week....Sly......
Later...Ron.M.....Cool....
(This post was edited by Ron.M on Apr 24, 2012, 6:52 PM)
Apr 24, 2012, 9:58 PM
Post #22 of 27 (28765 views)
That's one point I was attempting to make.
The other is that that remote, even if front panel keyboard is locked, should still, at least, turn the set ON/OFF (with the correct code installed).Smile
Download and look at the copyright date on the sheet itself.Shocked
(This post was edited by jts1957 on Apr 24, 2012, 10:00 PM)
Apr 24, 2012, 10:21 PM
Post #23 of 27 (28764 views)
I believe TIMER button on the Panasonic remote = SLEEP button on this remote.
mike03
Apr 26, 2012, 4:14 AM
Post #24 of 27 (28751 views)
To my best judgement the sleep button does the same as the timer button on the original. Nothing wrong in giving it a shot right?
MK
Apr 26, 2012, 5:03 AM
Post #25 of 27 (28750 views)
Presums you have the correct (working) Panasonic TV code entered into the RCA Universal Remote control.Unimpressed
