Jan 22, 2012, 1:05 AM
Post #26 of 33
(8260 views)
Re: [steveo82] pn50a550s1f Samsung Plasma Clicking
steveo82;.... The link that jts1957 posted works just fine.... http://elektrotanya.com/...sm.pdf/download.html When you get there , scroll down to a bit past half way... You'll see a sample cover page on the left side.... Immediately to the right of that sample page , you'll see "Get Manual" in reddish brown letters... "Get Manual" may take a bit of time to load up... Patience , it should appear soon... IF they don't , try refreshing the page... Click on those words & your download should start shortly... This manual is for PN50A550S1FXZC SM which is for your TV... GOOD LUCK........ Have a GREAT day & weekend.... BTW;...You're Welcome....... Another BTW:.... IF you have the SAME model TV & the SAME symptoms , logic says you have the SAME parts bad .... In this case , the main board.... See post #22... Later...Ron.M....... Veteran & Retired TV technician
(This post was edited by Ron.M on Jan 22, 2012, 1:13 AM)
