Hect7369
Apr 22, 2005, 7:11 AM
Post #4 of 4
(1015 views)
Re: [rodm] proscanmodel#PS52650 no power hot checks ok with trans tester nosound nothing lighting up
Well,If hot Power supply is Ok,start checking the Horiz/transistor for open or short conditions,check B+ voltage.If Horiz/trans.is good,and there is not B+,You probably, need to repair power supply.In stand by conditions,u should have B+. If Horiz/trans is shorted,this is loading the power supply,chirping sometimes is heard.Use original parts. work safetly. Hect.
