May 1, 2012, 8:39 PM
Post #6 of 9
(4282 views)
Re: [mel] samsung syncmaster p2270 hd black screen powerboard fault
mel;..... Your computer may already have a built in extraction for RAR files... Some Windows OS may have it.... After you download the file , right click on the file & see if "Extract All" appears... ("Extract All" will ONLY show up on zipped files) IF it does , you can do it without any further downloading... IF it does not , see below.... RAR & other file types are easy to open IF you use 7-Zip for extraction.... You can get it FREE here;=>.... http://7-zip.soft32.com/...Xy368CFcjb4AodtywfAQ After you install it , when you right click on zipped files you will see "7-Zip" with an arrow to the right.... When you download a zipped file such as the Samsung , create a new folder for the Samsung... Rename the new folder "Samsung"... Drag & drop the downloaded file into the new folder.... Open the folder... Right click on the Samsung file... Select 7-Zip... New choices will appear in a sub window.... Select "Extract Here" That will open up the file(s) & put all the info in the new folder instead of having the files scattered all over your desktop... See , wasn't that easy ??? Once you get the hang of it , it's a piece of cake.... ... No matter which system you use , ALWAYS create & use a seperate new folder to extract your files in... Reason is that some files have lots & lots of sub folders that will be scattered ALL over the desktop , My Documents , etc , IF you don't.... ... Yer welcome.... .... Later...Ron.M.... ... Veteran & Retired TV technician
(This post was edited by Ron.M on May 1, 2012, 8:42 PM)
