samsung tv capacitors
kbick1
Jun 18, 2017, 4:59 PM
Post #1 of 10 (1118 views)
samsung tv capacitors Can't Post
Hi, I'm trying to change the capacitors on my samsung tv since it won't turn on and this is a known issue. But none show obvious signs. Which ones should I replace from the image below? The larger 4 on the right?
https://www.flickr.com/...46@N08/shares/2vX4Wm
Jun 18, 2017, 7:10 PM
Post #2 of 10 (1114 views)
Re: [kbick1] samsung tv capacitors [In reply to] Can't Post
Are you sure that that set / board was from the limited number of years that Samsung was using sub-standard materials in their capacitors?
Most of those would make themselves visually apparent (puffed top / bottom or leaking).
kbick1
Jun 18, 2017, 9:20 PM
Post #3 of 10 (1107 views)
Re: [jts1957] samsung tv capacitors [In reply to] Can't Post
No, I'm not 100% certain. But unplugging the tv for a few minutes used to work, and that seems to be a symptom of the capacitors, from what I read. But if you have any other suggestions I'm open to hearing them.
Jun 18, 2017, 9:37 PM
Post #4 of 10 (1105 views)
HINT:
"""set / board"""
kbick1
Jun 18, 2017, 11:26 PM
Post #5 of 10 (1088 views)
Not sure what that means, sorry
Jun 19, 2017, 12:12 AM
Post #6 of 10 (1084 views)
Pick one (set) or give your own:
https://www.shopjimmy.com/samsung
and / or one (board)
https://www.shopjimmy.com/...rands_select=Samsung
https://www.youtube.com/watch?v=acI12jO0HSQ
(This post was edited by jts1957 on Jun 19, 2017, 12:23 AM)
kbick1
Jun 19, 2017, 8:13 PM
Post #7 of 10 (1073 views)
Ok, thanks. Don't see my model, and more expensive than changing individual parts, but makes sense to replace the entire board or set.
Jun 19, 2017, 9:27 PM
Post #8 of 10 (1069 views)
Since we only want to talk generalities ... That 'sounds' like it could be one or more bad joints on a BGA IC on a Main board.
kbick1
Jun 19, 2017, 10:08 PM
Post #9 of 10 (1063 views)
Thanks, but no need to be sarcastic - what type of specifics do you want? Be happy to provide any details that I have available.
Talk about generalities, not sure what
even means. If I was a tv repair person I'd know all this and wouldn't be on a forum asking for help.
Jun 19, 2017, 11:11 PM
Post #10 of 10 (1057 views)
Identify samsung set.
Identify samsung board.
Search for (options) - Page loaded in: 0.25 s on (CGI/1.1)
