please note that the model is 2197m3. sorry for mistake. chirath;....
I downloaded your TV manual....
I'm guessing you have some TV &/or electronic experience...
Is that correct ??? yes i have repaired tv audio..etc for 18 years time
Do you have a service manual for your TV ??? i have similar one 2199m5t
In my service manual , you have Sony chassis GP-1A....Correct ???
if i disconnect all 3 guns
HOW are you doing this ??? de-solder 6.8k resistors which is gose to KB,KR and KG
disconnect KG out and connect KR in to KG pin on the CRT base.
HOW are you doing
THIS ??? disconenct them with above way and connect via smal pice of wire to KG to KR on CRT and KR to KB
is there any way to fix this issue
Possibly ,yes , there is....
to me there will be short circuit in side the TV.
IF you mean pix tube , maybe , maybe not.... yes i have read some article so i thing the filamanet and KG short inside
Answer ALL questions...
PLEASE reply & we'll go from there....
THANKS.....
Later....Ron.M.....
