sony trinitron color spots
segawega
May 21, 2009, 10:07 PM
Post #1 of 5 (1822 views)
sony trinitron color spots Can't Post
hello my name is taylor im new here. i have a question about fixing my tv. i just a bought a 1986 sony trinitron console tv and it has a color spot at the top left corner and i would like to degauss it, in like a month or so i will be buying a external degausser for it. i would like to have instructions on how to degauss it the right way without messing up the color on the screen for i have not done this before. any help would be greatly appriciated
"its true when they say they dont make things like they used to"
(This post was edited by segawega on May 21, 2009, 10:19 PM)
May 23, 2009, 4:10 AM
Post #2 of 5 (1811 views)
Re: [segawega] sony trinitron color spots [In reply to] Can't Post
Generic response due to lack of a specific model or chassis number in the original post.
Open up the console and follow the degaussing coil wires to where it plugs into the main board. Very near plug there will be a thermistor that possibly just needs a lead to be resoldered to the foil.
May 23, 2009, 6:57 AM
Post #3 of 5 (1808 views)
Dont waste your money Sony has that inside your TV and you will not use it. After many years of a TV repairer I became sick of going out to a Sony with this complaint. I then unplugged the TV, told the customer to leave it off for 24 hours (Well I like to extract some pain, that way it sinks in) and I never had a recall. You are leaving your TV on standby, use the manual switch , and switch off overnight or unplug. If you have an issue after that, move the magnet thats in the coloured corner. That is not in but outside your TV, its a speaker or other such item. If you cant find it , turn the TV from say N/S to E/W if it clears its a magnet outside the TV find that and do not stuff around trying to fix a non existant issue.
segawega
May 23, 2009, 10:21 PM
Post #4 of 5 (1801 views)
Re: [rrobor] sony trinitron color spots [In reply to] Can't Post
okay sorry for not including the tv model # here it is KV-2782R.
May 24, 2009, 2:46 AM
Post #5 of 5 (1794 views)
Update to my prior post now that the model is known:
(Check this 1st - you may not have to purchase the manual degaussing coil)
Plug = "D-17"
Thermistor = THP601 (1-806-214-00).
(This post was edited by jts1957 on May 24, 2009, 2:50 AM)
