technika tv no power
angellonewolf
Jan 20, 2015, 10:07 PM
Post #1 of 23 (10350 views)
technika tv no power Can't Post
i have a technika 32 inch lcd 32-56 &lt;br&gt;product number tw32x56btcug402 &lt;br&gt; &lt;br&gt;the problem is there is no power i have removed the back and found the main fuse blown on the powerboard and a burn mark coming from the small coil by the side of the fuse &lt;br&gt; &lt;br&gt;if i can find a way off adding a pic this would tell a hundred words i know a small amount in general electronics &lt;br&gt; &lt;br&gt;from the mark it looks like it has blown and on a auction site the replacement board for the tv is £14 inc delivery &lt;br&gt; &lt;br&gt;i am just thinking that i would like to confirm that i am right and a new power board will fix it before going ahead or going through the board and replacing the broken parts but as £14 for another board a few parts inc delivery will soon add up it does not look like a few blown caps but this is why i am posting here to get your info on it &lt;br&gt; &lt;br&gt;thanks for any help angel &lt;br&gt; <br> <br>
(This post was edited by angellonewolf on Jan 21, 2015, 3:27 PM)
Jan 21, 2015, 5:09 AM
Post #2 of 23 (10332 views)
Re: [angellonewolf] technika tv no power [In reply to] Can't Post
http://www.tv-forums.com/...i?post=157911#157911
angellonewolf
Jan 21, 2015, 3:42 PM
Post #3 of 23 (10316 views)
Re: [jts1957] technika tv no power [In reply to] Can't Post
i mucked around a fair bit and cant get it to work but if you copy and paste this in to an address bar you will get the pic
https://imageshack.com/i/p9Y8w5bej
<br> <br>hope this is a clear picture and explains that i think i found the fault <br> <br>thanks for the help angel <br>
(This post was edited by angellonewolf on Jan 21, 2015, 3:43 PM)
Jan 21, 2015, 7:34 PM
Post #4 of 23 (10310 views)
That's a simply coil or choke. Ebay pix is also a bit unclear.
If one PAIR of wire leads attach it to the board, just check across them for continuity (with Mains line cord disconnected - either at pcb or at wall outlet). If TWO Pairs of wire leads attach it to the board, each pair should have continuity.
If you like, you could also connect Mains and measure for DC volts across the largest electrolytic capacitor (the one laying on its side with bar code label). Should be well over a hundred volts DC.
Do they label the 3 white connectors with each pins voltage or function?
angellonewolf
Jan 22, 2015, 8:54 AM
Post #5 of 23 (10298 views)
thanks jts
i have cheaked and there is 240 through to the power board
and up to the fuse as can be seen in the pic i have bypassed this with some 5amp wire in the hope it will come on and it was only the fuse blown but know they normally blow because there is a problem with a piece on the board
thats as far as i got
will try cheaking what you say and get back later
again thanks
ps do you think as can be seen from my pic its a blown choke that is the problem ?
angellonewolf
Jan 22, 2015, 9:41 AM
Post #6 of 23 (10296 views)
done some more work
more pics of the board with number marks
good pic of board
https://imageshack.com/i/hlWdnbu7j
pic of burn mark and where i think the problem is
https://imageshack.com/i/f0m2Thw6j
pic of back of board numbered
https://imageshack.com/i/p717muNej
number 1 is live/postive power will go from number 1 throught the fuse on the other side of the board to one side of the coil and got continuity through the coil to number 2 ok
number 3 is the netural goes up to the top of the 3 ok but has an open circuit throught the coil to number 4
this mean that the coil or choke has blown ?
Jan 22, 2015, 10:27 AM
Post #7 of 23 (10294 views)
Yes, coil is blown. Since you like to put in jumpers, solder a jumper between number 3 to number 4.
You may get the house breaker to trip, the jumper to go to little tin balls, foil(s) to fry &/or parts to char and smoke .... or the set will work.Wink
Of course, you could measure resistances across some major part looking for a low reading FIRST. A Dead shorted reading across a diode is a bad thing.
(This post was edited by jts1957 on Jan 22, 2015, 10:30 AM)
angellonewolf
Jan 22, 2015, 7:32 PM
Post #8 of 23 (10288 views)
yes thanks for that i will not be jumping the coil lol as even i assume its there for a reason and i only jumped the fuse with the same size fuse wire not a nail
what would be the aprox cost for a coil
and should i need to cheak any thing else eg poss could it have blown something else in the circuit as if it comes to to much i might be better replacing the board than just the coil ?
thanks for the replys angel
Jan 22, 2015, 9:08 PM
Post #9 of 23 (10284 views)
IF HAS low resistance readings (that would be the thing to check further).
IF NO low resistance readings are encountered (this would include the pins of the 3 white connectors, with reference to ground, with them all plugged in), THEN try jumpering the coil.
At that point you'd have little to lose before replacing whole board.
(This post was edited by jts1957 on Jan 22, 2015, 9:09 PM)
angellonewolf
Jan 22, 2015, 10:04 PM
Post #10 of 23 (10280 views)
another pic another story
https://imageshack.com/i/ip6ztG1sj
the only low resistance i can find is one in number 5 in pic is this another type of fuse 3.3
and low restance in number 6 in pic 1.2
i cant find any cross shorts from poss to neg or to ground around the board
and yes i have a rcd in the main board if you think i should be able to jump it
and yes i do it my own risk i know that lol
and feed back on the low Resistance i found
or shall i go a head with the jump
ps price if just the coil and fuse ?
again thanks for all the help
Jan 22, 2015, 10:42 PM
Post #11 of 23 (10273 views)
5 = VDR = Normal reading
6 = Resistor = Normal reading
Coil can still be used (enamel scraped off burnt lead then either add a length of same gauge wire to extend or unwrap, by one turn, the too short lead. Either one will require you to remove the coil and reinstall after modification.
Can't see through tubing thats covering, so I can't determine exact type, but should be similar (in physical size) to: http://www.ebay.com/...;hash=item5ad4acc7fe
angellonewolf
Jan 23, 2015, 9:41 AM
Post #12 of 23 (10265 views)
i must say what a great help you are especially the fast response thanks again
if i remove the coil that should not be a problem and remove 1 turn i assume solder a joint the wire together will i need to insulate as i wrap it through the coil ? or is the coil insulated from the wire ?
thanks angel
ps is it poss just to jump the coil to see if the unit works ? as a test ?
Jan 23, 2015, 11:18 AM
Post #13 of 23 (10263 views)
Toroids can be wound using conventional plastic insulated wire or with enameled insulated wire. For an enamel insulated wire to be connected to the outside world it has to have the enamel insulation removed. IF yours currently does NOT have the space to accomplish scraping off of the enamel insulation (or the length for the freshly exposed wire to be reinserted back through your printed circuit board), pushing the too short wire back through the 'donut' of the core is a way to accommodate both.
angellonewolf
Jan 23, 2015, 12:24 PM
Post #14 of 23 (10259 views)
Sorry for the stupid questions
Can I just reduce the coil wrap on both sides of the coil unwind both the positive and neg sides by one wrap and scrap and resolder with out causing any problems or are they wrapped a certain amout of times for current or voltage reasons
Thanks again
Jan 23, 2015, 12:53 PM
Post #15 of 23 (10257 views)
I've always just done the one side.
"Smaller chokes are used in switching power supplies to remove the higher-frequency switching transients from the output (and sometimes from feeding back into the mains input); these often have toroidal ferrite cores."
angellonewolf
Jan 23, 2015, 1:14 PM
Post #16 of 23 (10255 views)
So I can just unwrap one turn scrap and resolder back on to the board ?
Leave temp the fuse wire to replace the fuse that has blown
Plug all back up as should be with power board and cheak the plug live nutrual and earth and see if there are any shorts across any lines inc ground if thats OK I should be OK to try it ?
Turning on using a long stick lol ( rolls around laughing)
Thanks again this is very interesting I have had a few interests over the years computers and more recently petrol mowers and strimmers but having fun with this and cost is not as I got a fair bit of things to do this with
Jan 23, 2015, 1:46 PM
Post #17 of 23 (10254 views)
Yep.
angellonewolf
Jan 23, 2015, 2:05 PM
Post #18 of 23 (10251 views)
Thanks for the helps again I'm a work today but will try to have a go later will post back asap to let you know that I am dead or the TV turned on
Thanks angel
angellonewolf
Jan 25, 2015, 1:33 AM
Post #19 of 23 (10236 views)
good news its alive
i done what you recommended and unwound the coil by one turn and it snaped while doing so so had to do 2 turns scraped and soldered
the fuse went to local maplins bought 10 5a slow blow fuses for £3.09
soldered some wire on each end and soldered in to place to replace the fuse
and up it came i have been using it for about an hour tonight for the 360 playing will do so for a few weeks as i have a place for it to go a friend has just got in to geting fit and needs a extra tv so will prob donate it to her
and keep my eye out for another to play with
thanks for all the help on this one hope if i get any more i can use your help again
thanks very much angel
ps have an extra pint for me next time you are out you deserve it
Jan 25, 2015, 2:11 AM
Post #20 of 23 (10235 views)
Glad it worked.
Keep an eye on it for a couple of weeks - Don't leave it playing unattended.
A surge protector wouldn't hurt, and even then I'd suggest unplugging it during electrical storms.Wink
angellonewolf
Jan 25, 2015, 2:09 PM
Post #21 of 23 (10226 views)
i will be using it on the 360 for a few weeks and power will be switched off on the power switch not left on standby for this time
again thanks for the help i did enjoy playing and did bring back memory's from my sparks training years ago we had to do a part one of electronics for it as i have said had a few hobbies in the last few years keeping my self useful and my mind going
and its a lot warmer working inside and its not as seasonal as mower and trimmers and i have been offered one or to bits but might have to take a brake as got the bedroom to do in the next few weeks and having a tv apart in on the kitchen table did not make the otherhalf very happy untill see seen it working
mack G™
Jan 28, 2015, 8:54 PM
Post #22 of 23 (10185 views)
[message deleted]
mack G™
Jan 28, 2015, 8:55 PM
Post #23 of 23 (10184 views)
[message deleted]
(This post was edited by mack G™ on Jan 28, 2015, 9:26 PM)
