222wwwsssxxx
Dec 11, 2005, 1:28 PM
Post #3 of 8
(1373 views)
Re: [rrobor] tv as a light source for a photographic application
Thanks for the info, rrobor! But I will elaborate a little on the application. The tv would be used as a light source for an enlarger head. In this case, the light source must be cooler than standard bulbs and floods since it is close to a negative. Being able to vary the color in the blue to green region will allow me to vary the contrast of color sensitive black & white enlarging paper. Yes, I don't care if I destroy the tv if it will accomplish this. Can you give me more specifics on adding the resistors as you mentioned? Will I have a nice wide range of color change? Also, I would like to increase the brightness as far as it will go. Any thoughts on this? Any more circuit options? Your help is much appreciated!
