someone11;...
And i can soldier.
Is there a place i could just buy that whole board so i avoid soldiering?
Conflict of interest ????
OR just lazy ???
Answer is yes...
I'm doing some research on your TV as we speak (?)...
I need about an hour & I should have some better info for you...
Side note, with the panel unplugged the tv comes on by itself when plugged in to the wall.
Where is the volume level at ???
All the way down , partly up , midway or ???
Can you remove the panel & see if there is any corrosion on or near the switches & the IR receiver ???
While you're at it , see if there's a label or part number printed on the board OR label...
Please post it...
THANKS...
There are some places that you can buy that board...
Shopjimmy is one that you can trust...
But , it will cost you much more that the switch(es) will..
AND , part numbers ARE CRUCIAL !!!
MUST be CORRECT !!!
But , as I've said in the past:=>...
It's your TV....
It's your money....
It's your call...
Later...Ron.M...
