Mar 15, 2015, 5:04 PM
(3829 views)
Re: [pounder] Blaupunkt RTV-926 (rebadged Panasonic) SVHS VCR keeps ejecting tapes
A tarnished NOS MODE switch is as bad as a tarnished original MODE switch. I'd carefully take apart the switch, run a typewriter eraser (you may use pointed eraser on a pencil) around each 'track' until it shines, brush out debris, spread a small amount of a non-hardening grease around inside and carefully reassemble. If metal shorting piece is not at approx. 45 degree angle, hold your thumbnail at bending point and gently bend up to about 45 degrees with a flat screwdriver or trowel. Make sure MODE switch engages contacts on PC board. Check solder joints on all stand-up sensors. ------------------------- Location: Far, Far Away
(This post was edited by jts1957 on Mar 15, 2015, 6:12 PM)
