tejasnaidu
May 19, 2010, 11:55 AM
Post #3 of 6
(2008 views)
Re: [jts1957] Panasonic NV SJ530 tape speed problem
Before checking the PS for problems, i removed the backup lithium memory backup battery. Reinstalled the battery. Now when the tape is inserted, the tape is seated the spool spins 5-6 rounds and tape is ejected. The tape is not wound around the head. The tape simply is seated, spool wound and ejected. Removed the assembly and found mode switch in wrong position. cannot move the gear assembly above the switch to proper position by hand. Removed battery and reinstalled. Same problem. How to bring the gear mechanism to proper position. The arrow markings are 90 deg apart.
