tundrawolf
Dec 16, 2009, 9:42 PM
Post #5 of 12
(3333 views)
Re: [jts1957] Panasonic VCR stops mid tape?
Before this incident, when playing, the tap would slow down intermittently, like someone playing a record and applying pressure to the turntable to slow the music down. I thought "Binding", so I took the unit apart, and applied oil and grease to areas where it was needed. During this, though, I discovered a sort of "torque converter" connected to the drive motor, so that if the tape reaches its end, it will not over stress the drive band, and will allow for slippage. I studied the mechanism, and found that it only took very light pressure to stop the mechanism from turning, and that my donor VCR allowed a lot less slippage. So, I took a Q-tip and covered it in some very thick grease, and grease the internal contact points. It allows slippage now, but it is stronger, definately. Could it be possible that the cassette tray mechanism isn't seating fully and allowing the tape to pack at an angle? Would this cause the binding I am experiencing?
