Nov 6, 2008, 8:30 AM
Post #7 of 7
(8959 views)
Re: [arlener] Panasonic PV-V4620 VCR won't eject tape
Its not a model Im familiar with but the usual with panasonic is the loading arm on the left which holds the input guide. IE tape out of cassette round the input guide round the drum round the output guide then back in box. The input guide strips gears so the thing locks up. Here the arm that drives that costs $29 which for what it is is rediculous. but to fix you will need it. To get the tape out, you need to remove a screw on the front right side of the carriage, somewhere round the top right corner of the cassette box. With that screw out, you can then lift the carriage enough to jump the gears and lift the tape out. With the tape out then you can get into the rest of the screws to unplug and lift the deck out. With that out its easy to check the gearing. If you do fix it and dont change the gear it may work but will jump out on the first tight tape. Timing of gears is easy, on these its not rocket science.
