Sony SLV-795HF Mechanical Failure & Error Code
Quadrox
Nov 28, 2006, 6:47 PM
Post #1 of 2 (261 views)
Sony SLV-795HF Mechanical Failure & Error Code Can't Post
I'm trying to repair this VCR...
If you enter stop or play while the machine is in fast forward or rewind (or allow it to go to the end of the tape and enter stop by itself), the deck will stop and the loading motor will run for a few seconds, then the deck will shut down and display the error code "3L 10cc".
If you wait for 10 seconds more, the machine will reset & work until it has to stop in fast wind again, then it will go back into the same failure mode. Deck will load, play, and eject normally when not in this failure mode.
The mode switch was removed, cleaned, and replaced, but this did not fix the problem.
Does anyone have any suggestions, or know what the error code means?
-Thanks
Nov 29, 2006, 3:22 PM
Post #2 of 2 (251 views)
Re: [Quadrox] Sony SLV-795HF Mechanical Failure & Error Code [In reply to] Can't Post
one of the tape end sensors may be faulty.when in play mode shine a torchlight onto the sensor(left side) and see what happens. if nothing the sensor is faulty.or try the right hand sensor when in rewind.
Search for (options) Web Design by Web Ideas - Page loaded in: 0.40 s on (CGI/1.1)
